email support
Problems trying to forward e.mails
td123
Whizz Kid
Message 2 of 2
For the last few days I have been having problems forwarding e.mails from my tiscali.co.uk mailbox.. I usually forward possible phishing mails to report@phishing.gov.uk and  phishing@talktalk.co.uk but have been getting this error message.
An error occurred inside the server which prevented it from fulfilling the request.
I have tested the "send" function and that works fine and also tested the "forward". Of these all tests have gone through to another e.mail address I have, but very few make it successfully to either of the phishing reporting sites.
Any thoughts
Btw. -  I have run full scans with Avast antivirus & Malawarebytes - all came back clean.
1 REPLY 1
Billx
Message 1 of 2
Hi, @td123
Apparently, forwarding from a TalkTalk domains email address, has already been suspended/banned.
I.E. don't use forward.
Creating a NEW email, attaching the email that you want to forward, and sending, will achieve the same thing.
Bill
