Broad band not reaching other rooms
yelsel1
Message 24 of 24
I live in a smallish bungalow. Broad band does not reach my bedroom. 11yards away. I have been using a TP link. About 9 years old. This has stopped working. Bought a new set. Cannot get it working
23 REPLIES 23
Message 1 of 24
Thank you for the support @KeithFrench 🙂
Message 2 of 24
Thanks very much. Technology has just passed me by. My brain goes to mush.
Message 3 of 24
Hi @yelsel1
When you get the booster, if you have any problems, I can help with both products.
Message 4 of 24
That's wonderful news, let us know how it goes. Thanks
Message 5 of 24
Thank you so much for your help and patience. Hopefully sorted. I have ordered a Sagemcom  wi fi booster.
Message 6 of 24
Thank you so much for the support @KeithFrench
Hi there @yelsel1, the information provided by @KeithFrench is correct i would also recommend you purchase Sagemcom FAST266 Wi-Fi Booster
Message 7 of 24
Purely to extend an Ethernet cable over your mains electricity, nothing else. They will not improve your Wi-Fi reception at all.
Message 8 of 24
The old ones worked for 9 years.
What are theseTP links intended for?
Message 9 of 24
They will not help you extend your Wi-Fi at all. The easiest & best way to extend your WiFi coverage is to buy a Sagemcom FAST266 Wi-Fi Booster. These are available from the Better Value Team, just buy one single unit for £30 (assuming they are still half price) plus delivery.
To contact the Better Value Team (old Legacy Dept), please call:  0345 1725157.
Opening hours:-
Monday to Friday 09:00 to 19:00
Saturday 09:00 to 18:00
Sunday Closed
Message 10 of 24
My router is at the east end of my home.(small 3 bed bungalow) The computer is next to it. The master phone socket is here also. It was moved by an engineer couple of months back from middle of home,but it did not improve wi fi . Engineer coming today to sort it out. Wi fi has never reached the west side of home. I had TP links in use for about 9 years. These recently stopped working . So I bought new. Exactly the same. I cannot get them working .It is to use Ipad .We only have 2 i pads + tele, and not much other devices
Message 11 of 24
Please forget all about Ethernet cables at the moment.
Please explain what you are trying to connect to your router and why you think you need these TP-Link devices will help you?
Message 12 of 24
Sorry to be dim. i just dont understand tec talk found a blackmarked lan cable eternty
Message 13 of 24
Only the yellow one will be correct. However, as I asked before, what are you trying to achieve with this setup?
Message 14 of 24
I have a yellow marked data cable.and a grey not marked. Both talktalk
Message 15 of 24
I have found another grey cable
Message 16 of 24
Ethernet cables can be any colour. If it is a TalkTalk-supplied one that is yellow. If the grey cable was supplied by TalkTalk, that is not an Ethernet cable at all, but an ADSL/VDSL cable. This is an example of an Ethernet cable:-
https://www.amazon.co.uk/Amazon-Basics-Gigabit-Ethernet-Networks/dp/B00N2VISLW/ref=sr_1_21?crid=1C3K...
However, if you do not know what a wired device is, what do you want to use these TP-Link's for and what sort of device of yours do you want to connect to the router via them? Your TP-Link units, as I said before, cannot connect to wireless devices at all, only Ethernet ones.
Message 17 of 24
an ethernet cable is grey? i only have 1. will a data cable work? what is the wired device to connect to
Message 18 of 24
I used to have a set of those Power Line Adapters and they were fine for extending the Ethernet ports. They have no Wi-Fi component to them at all. There is no router configuration required with them. You do not need any TP-Link utility to get them to work.
If you connect an Ethernet cable from one TP-Link to an Ethernet port (not WAN port) on the Sagemcom, and from the same on the other unit to your wired device, what lights are shown on each TP-Link?
Message 19 of 24
Pass through powerline  starter kit. TL-PA4010P kit
Sagemcom router.
The instructions for installing have been tried numerous time.
I am not the best for understanding technical terms
Message 20 of 24
Thank you @ferguson
