Router Connection Problems Last week or so
JaceyBoy
Whizz Kid
Message 23 of 23
Can I request a new router please, over the past week or so ive been having issues with the super router, have tried to factory reset (which did in the end) but it didnt want to, and struggling to connect security cameras, and also other network devices.
Jason
22 REPLIES 22
Message 1 of 23
If you experience the issue again, get back to us and we will be able to assist you further.
Message 2 of 23
Never had this before, I come on here before and tell them its faulty as Ive run my own diagnostics and know when its a router fault or equipment, its working okay right now but cant say it will stay like that.
Jason
Message 3 of 23
To determine if it is a router issue and if it is then a new router will be order for you. However, if you need a router without the fault being detected, I will be able to order one for you and you will be required to pay for the equipment.
JaceyBoy
Whizz Kid
Message 4 of 23
What checks do you want to do?
Jason
Message 5 of 23
I completely understand, we will need to run checks and if it is a router issue, we will be able to place an order for you.
Message 6 of 23
I will monitor is over the next few days but I have had this problem a few years back and it was the router and only a new one solved the problem!
Jason
Message 7 of 23
I understand that it was experiencing issues earlier, and it's good to hear that the connection has improved since the factory reset.
However, please note that we are unable to run checks or diagnose any potential problems if you're not currently experiencing the issue. If you encounter any difficulties again in the future, please reach out to us, and we’ll be happy to assist you further.
Message 8 of 23
The Ring camera was playing up but this was down to Ring today, we have been struggling with connection last week with devices, its better now since ive factory reset but dont know how long it will last.
Jason
Message 9 of 23
Thank you for confirming, you have advise that you are struggling to connect to cameras and other devices, do you get a security warning or an error message?
Message 10 of 23
No I am not
Jason
Message 11 of 23
Are you experiencing dropping connection on your line?
Message 12 of 23
Its been on and off,  am currently connected after rebooting the router twice.
Jason
Message 13 of 23
Just to confirm you are unable to access the internet on those devices.
Message 14 of 23
Yes had no issues before, but the last few days the router has struggled, devices like my laptop have not been able to connect, so I did a factory reset whch would not work via the reset button on the back, I had to connect via ethernet and after second attempt it worked.
Jason
Mandisa-TT
Message 15 of 23
Great! You have advised that you are unable to connect to other devices, can you confirm if it was devices that you were able to connect with before?
Message 16 of 23
Yes I am
Jason
Message 17 of 23
Thank you so much @KeithFrench for your help.
Hi @JaceyBoy I will be able to run checks on your line, are you at home to be able to proceed.
Message 18 of 23
OK, that's fine. I did ask TalkTalk to investigate this for you, as promised, so please wait for them to respond now.
Message 19 of 23
Yes I have
Jason
Message 20 of 23
Have you checked, though?
