Tuesday
I’ve had a stable FTTC connection since 23 May, with upstream consistently around 6.5 Mbps and attainable around 10 Mbps. SNRM was steady at ~10 dB and the line had been up for around 16 days with no issues.
Today the upstream has suddenly collapsed to:
Downstream remains normal at ~28.6 Mbps with attainable ~47 Mbps.
Attenuation is unchanged.
No changes to internal wiring or equipment.
This is an upstream‑only line fault, not DLM and not a router/Wi‑Fi issue. The pattern matches an HR fault, water ingress, or a cabinet port problem.
Could you please raise this with Openreach for:
The fault is active right now.
John
Tuesday - last edited Tuesday
@oldjohn1945, you need to try to reach Chat through My Account or phone 03451 720088 for technical support - there's no staff support on the forum any longer.
Details of opening hours here:
