on 02-04-2024 01:54 PM
Having a problem with speeds. Ookla which I’ve used for years tells me 20M whilst TalkTalks own tells me the speed is normal. I’ve tried others and some say it’s all okay, others say very slow. TalkTalk also shows there might be a problem on the line. I’m confused! Please study photos.
on 03-04-2024 06:55 AM
Hi @RichP7
I'm so glad to hear that the throughput speed has now increased 🙂
If you do experience any further issues then please let me know.
I have sent you a Private Message with a link to a short survey for the Community.
on 02-04-2024 04:10 PM
Thanks Debbie, the prompt reply and sound advice is very much appreciated. Your advice has been followed and speeds are consistently good and what I have become accustomed to expect 👍 Ping is 16 would normally be 11 or 12 on the Leeds aql server. Hopefully all put to bed now!
Best regards, Rich.
Current download speed.
on 02-04-2024 01:58 PM
Hi RichP7
Apologies for this.
The sync speed looks ok. Please can you power down the router for a full 30 minutes and then run another speed test?
