Why can't I access the Spanish Timetables ?
Steamywee
Super Duper Contributor
Message 26 of 26
Unable to get "https://www.tib.org/en/linies-i-horaris/autobus/-/linia/A11"
That's pretty much it!
Down for everyone says its up, TalkTalk can't access it either by PC or Phone.
If I switch off WiFi, I can get it using my O2 connection!
WHY are TT blocking this site?
Are we now under Donald Trump's rule?
Hopefully not, but it begs the question what other info are TalkTalk stopping us from viewing, or are unable to connect us to?
25 REPLIES 25
Message 1 of 26
Have a great day!
Steamywee
Message 2 of 26
Message 3 of 26
True, Hopefully the forum platform fix won’t be too far off, but at least this workaround is keeping things moving in the meantime. If you run into anything else or need a hand with the router thread or anything holiday‑prep‑related, just give us a shout @Steamywee — we here to help!
Message 4 of 26
@Steamywee thats good to know.
At least my suggestion is a work around until they get this fixed.
Message 5 of 26
That’s brilliant — I’m really glad the copy → refresh → paste → post workaround did the trick for you! 🎉
Steamywee
Message 6 of 26
Just used your "Copy/refresh/paste'npost" solution on the router problem thread and it worked fine!
Message 7 of 26
Our team has raised this with the Forum Manager, who has passed it on to the forum hosting company for investigation. We’re waiting on their fix, and we appreciate everyone’s patience in the meantime.
We definitely do want you to have your holiday, and we’re here to help get things working smoothly again. Hang in there
Steamywee
Message 8 of 26
@fr8ys Someone doesn't want me to have a holiday! and the universe has turned against me!😭
Message 9 of 26
Thank you @fr8ys
Message 10 of 26
@Steamywee re the forum not completing the action, i.e. you cant post, weve raised this with the forum manager, who has raised it with the forum hosting company.
In the meantime try to avoid paragraph breaks as the message will then pop up.
We've found finishing the message, then selecting all and copying, refreshing the page, hitting reply and pasting is the best way, albeit convoluted, round this issue.
Although on this message I originally avoided breaks but it still failed! Oh well.
Steamywee
Message 11 of 26
@Mandisa-TT Already tried that and if anything it's worse!
Loading time for any web address is very very slow and sometimes times out. 😞
Edit:
Started a thread here:-
https://community.talktalk.co.uk/t5/Fibre/Router-Problems/m-p/3142412#M404987
Message 12 of 26
@Steamywee I'm really sorry to hear you're dealing with this — especially when you’ve got important things to sort out and limited time.
From what you’ve described, it does sound like your router may be struggling. The first thing to try is a full power cycle:
  • Switch the router off at the socket
  • Leave it off for 30 seconds
  • Turn it back on and wait for all the lights to stabilise
Once it’s back online, please check if web pages load normally again.
Steamywee
Message 13 of 26
@fr8ys Ah! I think it's my router on the fritz.
Most of the time now (today) I'm having to load web pages at least twice as the tabs can't detect an internet connection!
Bloody nightmare as I'm trying to organise Bank stuff, sort out Holiday details etc and have only a week to do it all as well as packing!
Could have done without any more problems
And on here it constantly tells me It "can't complete the action you requested" when I've not requested anything!
"AArhhh"
Message 14 of 26
Thank you @fr8ys
Message 15 of 26
@Steamywee I was using WiFi, not data. I must have checked just after the fault cleared.
I was just testing to help Keith.
Message 16 of 26
Hi @Steamywee thank you for confirming and your stated on your last post that the issue that you had has cleared up.
Steamywee
Message 17 of 26
@fr8ys As stated in my original post, I too can connect to the site using my O2 connection if I turn off WiFi on my phone
Message 18 of 26
We are glad to hear that @Steamywee.
@fr8ys seems like blockage is cleared now, thanks.
Message 19 of 26
Great, @Steamywee thanks for that, one less to deal with.
Steamywee
Message 20 of 26
Hi again Keith, looks like the blockage is cleared now!
I've managed to connect!
