2.4ghz not 5ghz.
Daisyroo77
Message 4 of 4
My security camera does not work with my new router. It needs to be 2.4ghz not 5ghz.
3 REPLIES 3
Message 1 of 4
Hi @Daisyroo77 the 2.4 ghz connection is more robust in terms of range, the 5 ghz in terms of interference. I've never noticed a significant difference between the two.
From the 29th of March our TalkTalk Community will move to peer-to-peer support and the TalkTalk team will no longer be here to support with queries. Don't worry we still have plenty of ways to reach out if you need to speak to TalkTalk directly. For more details check out the link here: How to contact TalkTalk Broadband - Help & Support. 03451720088
Daisyroo77
Message 2 of 4
Thank you. It works now. I noticed when I looked at the advanced router settings again my camera is in the 2.4ghz column, but also one of our mobile phones. Does that mean the speed on that phone will not be as good?
Message 3 of 4
Your router supports both 2.4 and 5ghz channels so your camera should work.
See if you can disable the 5ghz channel temporarily in your router dashboard or of an Eero you van troubleshoot the issue which will lead you through the process.
Once connected restore the 5ghz channel for other devices to connect.
