Can I use a FAST 5464-2 for Voip
Redeel
Message 6 of 6
I have been without my landline for nearly 4 weeks. TT sent me a Eero Router but despite numerous attempts to set it up, it will not connect to the internet. They also sent me a Digital Voice Adapter. The Technical Support Team have told me that I can use my existing router with the Digital Voice Adapter. When I connect the landline I get the message "Device not registered" This is the router that I have. Help please.I have connected the landline to the phone port via the Digital Voice AdapterI have connected the landline to the phone port via the Digital Voice Adapter
5 REPLIES 5
Message 1 of 6
Thanks for advising @KeithFrench. Please let us know once you have checked @Redeel .
Message 2 of 6
If you log in to the 5464 @Redeel, you need to make sure that the phone is registered; otherwise, there may be a problem with the DV network on your account.
On the router, look at the initial dashboard area & go to the MyPhone panel, it should tell you there.
Redeel
Message 3 of 6
Thanks for that. The problem is that I get conflicting messages from the TT Tech Support Team. Sometimes they say I don't need the DVA, sometimes they say I do. Also they say that if I am with City Fibre I need but if I'm with Openreach, I don't. I am with City Fibre. Would you believe that with this fault I have spoken to the Tech Support Team 31 times 😞
Message 4 of 6
Thanks for the advice @Gliwmaeden2
Gliwmaeden2
Message 5 of 6
Your phone should simply go into the slot for it at the back of the router, @Redeel.
The DVA only works in connection with the Eero.
If that doesn't work, you need to report back again.
