on 04-08-2025 08:51 AM
I have full fibre 65 with a Sagemcom Router, version FAST 5464-2. T4.
It is clearly faulty and I think I need a replacement.
Over the past few years it has taken sometimes several hours for the flashing orange light to turn white after the power has been turned off. ( About three occasions)
Each time I reported this and spoke to a customer helpline and went through several checks but with no solution. Luckily the white light came on hours after my speaking to the assistant so I didn't need to take it further
Yesterday, I had a power cut but this time the router LED has not flashed white just orange even after over 15 hours.
I have completed all the normal attempts at a solution...
Eg power off 20 minutes, etc.
The internet is coming into the house as the ethernet cable from the white wall box works. Just no internet from the router.
A new router is, in my opinion, the only solution.
Answered! Go to Solution.
on 04-08-2025 12:05 PM
Phoned the number and told to communicate by text. Copied my post to the text and got transferred to technical. Copied the post message again and after a few exchanges if questions and answers was offered a new router. Took about 45 minutes so not bad service.
on 04-08-2025 11:17 AM
Thanks for the reply.
I'll give them a ring.
I'll post how I get on in case anyone's else has a similar problem.
Can't say I'm optimistic on previous experiences on the phone to talktalk.
on 04-08-2025 08:55 AM
The TalkTalk support staff on this forum do not currently have access to the Full Fibre systems. Therefore, you will need to contact the Full Fibre Helpdesk on: 0345 172 0074.
Their opening hours are Monday-Friday 08:00 to 19:00, Saturday 09:00 to 18:00, Sunday: Closed.
