Faulty Router
chris45
Message 4 of 4
I have full fibre 65 with a Sagemcom Router, version FAST 5464-2. T4.
It is clearly faulty and I think I need a replacement.
Over the past few years it has taken sometimes several hours for the flashing orange light to turn white after the power has been turned off.  ( About three occasions)
Each time I reported this and spoke to a customer helpline and went through several checks but with no solution.  Luckily the white light came on hours after my speaking to the assistant so I didn't need to take it further
Yesterday, I had a power cut but this time the router LED has not flashed white just orange even after over 15 hours.
I have completed all the normal attempts at a solution...
Eg power off 20 minutes, etc.
The internet is coming into the house as the ethernet cable from the white wall box works.  Just no internet from the router.
A new router is, in my opinion, the only solution.
3 REPLIES 3
chris45
Message 1 of 4
Phoned the number and told to communicate by text.  Copied my post to the text and got transferred to technical.  Copied the post message again and after a few exchanges if questions and answers was offered a new router.  Took about 45 minutes so not bad service.
chris45
Message 2 of 4
Thanks for the reply.
I'll give them a ring.
I'll post how I get on in case anyone's else has a similar problem.
Can't say I'm optimistic on previous experiences on the phone to talktalk.
Message 3 of 4
The TalkTalk support staff on this forum do not currently have access to the Full Fibre systems. Therefore, you will need to contact the Full Fibre Helpdesk on: 0345 172 0074.
Their opening hours are Monday-Friday 08:00 to 19:00, Saturday 09:00 to 18:00, Sunday: Closed.
