Saturday
After some advice please.
Just upgraded from 150mb to 900mb a couple of days ago. I had 2 x Eero 6 with the 150mb. One with the desktop pc and the other in the living room connected via ethernet. I had a solid 150mb both ethernet and Wifi whever I was in the house and coold reach outside. The 900mb has come with a Hub 3. Set it up and got great wired speed 900mb+, the Wifi test next to the hub drops to 750mb and then in the living room it's 300mb. I know Wifi speeds will drop but the Hub seems pretty weak to me. I live in a bungalow and the living room is only 10 yards away from the Hub. My question is, can I add an Eero 6+ in the living room via ethernet or can I ditch the Hub3 and buy a pair of Eeros and jusy use these? They seemed a more solid connection than this Hub3. Thanks
Monday
Thank you so much for the support @KeithFrench
Saturday
No @ferguson, still on 150 at the moment, but have been dealing in depth with others who are.
Saturday
@KeithFrench are you on a 900 service now?
Saturday
For the money, it is a no-brainer - the Hub 3 & FAST266 Booster. I have fully tested these & think that they are pretty good. To contact the Better Value Team (old Legacy Dept), please call: 0345 1725157.
Opening hours:-
Monday to Friday 09:00 to 19:00
Saturday 09:00 to 18:00
Sunday Closed
Saturday
Thanks for th info Keith, The Eero I was thinking about was the Eero 6+ or the Eero Pro 6E as I thought they would give me a decent Wifi speed if I connected it via ethernet and put it in the living room. It's the same as I had with the 150mb and 2 eeros, one as the main router and one in the living room. I was just looking for a stronger signal in the living room and what options I had with additional hardware.
Saturday
Hi @dobbor11
You shouldn't mix eeros & Hub 3s, one or the other. By eero 6+, what do you mean: the eero 6 as supplied originally with FF150, the eero Pro 6 supplied with FF500 & above, or another eero model? I have seen that if you have multiple eero 6's on FF500 & 900, the backhaul (connection between the two units) does not seem fast enough; you would probably have to use an Ethernet backhaul. That is reasonable, because TalkTalk used to supply the eero Pro 6 for this.
The Hub 3 can be extended with the Sagemcom FAST 266 WiFi Booster; however, the name does not do it justice. It combines with the Hub 3 to form a Wi-Fi 6 mesh & I think it is a very good solution. These are, I think, still available for £30 plus delivery from their Better Value Team.
Your problems may well be caused by too much Wi-Fi interference & I can help a lot with that.
Just for reference:-
To answer this requires both a long & complex reply, so no apologies for this.
The Full Fibre 500 or 900 packages often mean that customers do not achieve the speeds they expect (obviously around 500 or 900Mbps). Firstly, you typically do not need the fastest speed possible on just one device, but rather enough speed to accomplish your tasks without compromising performance across all devices. As an example:-
However, I can help you achieve the fastest speeds possible on your devices. This is often not an issue with the design of these services, but rather the connection between these devices and the router. Your device must not be connected to the 2.4GHz Wi-Fi band; otherwise, it will never deliver such speeds. No other devices must be in use at the time of any speed tests, because Wi-Fi is a shared medium. This means that it works half-duplex (one direction at a time), device A transmits and receives its data separately. Then it is the turn of device B, followed by C, etc.
The Wi-Fi network adapters in these devices often cannot deliver speeds as fast as the fibre service can. Take the example of some older Wi-Fi 5 (802.11ac) adapters, which might work at speeds up to 433Mbps only if used in a perfect wireless environment, which most homes are not. When an internet speed test is performed, the speed achieved is down to the slowest link in the chain, namely the 433Mbps Wi-Fi adapter. Speed tests in this case might achieve somewhere around 400Mbps or less.
Older Ethernet connections can suffer as well. If a device only supports the 10/100Mbps standard, not 1000Mbps (1Gbps) or even the newer 2.5Gbps available on some desktop PCs, they are likely to only record 100Mbps on a speed test.
To get close to the 500/900Mbps on a speed test, that device must either have a minimum of a 1Gbps Ethernet connection or, if wireless, a faster Wi-Fi adapter. This would be a higher specification Wi-Fi 5 (802.11ac) or Wi-Fi 6 (802.11ax) adapter.
While Wi-Fi 6 is not designed to boost download speeds significantly, the new features will allow more connected devices. That said, faster speeds (up to 2.4Gbps) will be available if the environmental conditions in your property allow the use of a 160MHz channel bandwidth. Using 160MHz requires a very clean RF spectrum — a wide contiguous block without DFS radar activity or interference. To fully understand this requires detailed knowledge of channel allocation for it to work; otherwise, the router will fall back to an 80MHz channel bandwidth. Simply enabling 160MHz in the AP configuration is nowhere near enough. Currently, this means that it is very unlikely to work in the 5GHz Wi-Fi band, as all 160MHz channels cross into the DFS channel range (52 - 140); only the 6GHz band with Wi-Fi 6E or Wi-Fi 7 can be used.
I would not recommend using multiple eero 6 units on the FF500 or 900 services. TalkTalk, before supplying the Wi-Fi Hub 3 for these packages, used to provide the eero Pro 6 for them. One reason is that the eero Pro 6 is tri-band (1 x 2.4GHz and 2 x 5GHz Wi-Fi bands), allowing the backhaul network (connection between eeros) to maintain a faster speed. The eero 6 would therefore probably need an Ethernet-connected backhaul rather than using wireless, if it is required to use these slower, dual-band eeros. It may also not switch data fast enough for the increased speed of these packages.
There are some basic checks that you can do to ensure that your devices have the best chance of achieving these higher speeds:-
