on 19-11-2023 02:32 PM
I have managed to get hold of an ONT enclosure. How easy is it to pull the Fibre Optical Cable out of the ONT ? Are there any hidden clips that need to be disengaged before it will disconnect? As I have to feed the cable through the back of the box I don't want to break any thing.
on 20-11-2023 09:59 AM
on 20-11-2023 09:58 AM
Hi @Anonymous
This Openreach video website includes a video that demonstrates what member @G8YDE is hoping to achieve by fitting a casing for the already installed ONT.
I hope this helps.
Gondola Community Star 2017-2024
Like below to appreciate my post . . . Mark as solved Accept as Solution
on 20-11-2023 07:09 AM
Apologies for the confusion, what issues are you experiencing with the ONT?
19-11-2023 03:54 PM - edited 19-11-2023 03:56 PM
If the green fibre optic plug is like most just grip the sides of the green plug and gently ease out.
The first thing you'll notice is that the LOS led will go red. That's if you still have the ONT powered.
Tips:
