on 17-12-2025 07:26 PM
Our Full Fibre broadband and TalkTalk landline have both stopped working, and I've been unable to get through to a human agent despite multiple attempts over several days/eves. We're in the Coventry CV3 area.
Fault Symptoms:
Troubleshooting Completed:
Assessment:
The ONT lights being solid green seem to suggest the Openreach fibre connection is healthy. The issue appears to be either a faulty router or a provisioning/authentication problem on TalkTalk's side.
Request:
Could a member of staff please investigate and advise whether this requires a replacement router or a fix at TalkTalk's end?
Happy to provide account details via PM.
Thank you.
on 22-12-2025 07:07 AM
Hi there
@KeithFrench Thanks for helping out:)
@JeanC_2025 please try to perform a factory reset as suggested by @KeithFrench.
20-12-2025 04:16 PM - edited 20-12-2025 04:19 PM
Hi @JeanC_2025
You could try a factory reset of the router. One way to do this is to press the small reset button by the power connector, whilst the router is turned on. Hold it in for about 10 - 20 seconds or until the light colour changes.
If that does not work, then you probably need a replacement router. The full fibre helpdesk is the only team that can assist, as the support staff on this platform currently do not have access to the FF systems.
on 18-12-2025 07:21 AM
Hi there @JeanC_2025 please contact the full fibre team using the details below:
Contact Number: 03451720074
Opening Hours:
Mon-Fri: 9am-7pm; Sat: 9am-6pm; Sun: closed
http://community.talktalk.co.uk/onlinechat
Mon-Fri: 8am-9pm; Sat: 8am-7pm; Sun: 9am-7pm
