Ghost calls on voip landline
JuneRoger1
Message 4 of 4
Hi, experiencing this issue with voip landline receiving calls at 19 and 49 past the hour every hour with no sound when ringing and showing as no number. Is there a way to fix this? Have only had full fibre installed this week so assumed it may be tests being ran on the line but just concerned if it‘s something that may last longer.
R. Wood
3 REPLIES 3
Message 1 of 4
Hi @JuneRoger1
Has everything been working ok since the fix was applied?
Message 2 of 4
Hi @JuneRoger1
Apologies for this. I've applied the fix that will resolve this issue.
I will check in again with you next week to make sure that these calls have stopped.
Gliwmaeden2
Message 3 of 4
It's a known issue, @JuneRoger1. Easy to resolve when staff reach your thread tomorrow.
Please complete your community forum profile details for them to identify your. Go via your avatar; settings.  Add your Talktalk phone number or account number in Personal Information. Scroll down further to find the button to SAVE CHANGES.
