on 01-07-2025 04:21 PM
I have received a demand to return Eero router s/no. NCAW06G87KYGX4E
1. I do not have the prepaid label, which I used to send a previous router back some months ago.
2. I still need the router to fill in a dead spot.
Please advise
Denis Campbell
Answered! Go to Solution.
on 04-07-2025 08:22 AM
Good morning @Crapservicetwice. We're sorry to hear this. Please start your own thread so that we can look into this for you.
on 03-07-2025 11:36 PM
Most Talktalk emails seem to come from No Reply addresses.
For any billing issues you can contact Talktalk on 03451 720088 daytime, Monday to Saturday.
If you don't wish to use phone or Chat, please return to the message board here and click on start a topic.
You can't get staff attention on the forum unless you start your own thread
on 03-07-2025 11:31 PM
There seems to be a lot of this about, I have also just received an email threatening to make a fraudulent charge for not returning an eero. The email states that I requested a replacement eero and now have to return the faulty one. The thing is that I have never requested or received a replacement eero. What happend was that I requested a third eero as I was entitled to do under my contract, as I could not get two eeros to cover my whole house. This is the second time I have been threatened with baseless charges for the same non existent occurrence.
Contacting Talk Talk to complain is a nightmare, I tried replying to the email, but no that would be too easy.
I tried the chat feature which promised to get me an expert then just sat there doing nothing.
on 02-07-2025 04:54 PM
on 02-07-2025 04:52 PM
I've removed your account number from public display that was mentioned in the course of your Chat transcript.
on 02-07-2025 04:18 PM
Take care, you know where to find us should you require any assistance in future. Thanks
on 02-07-2025 03:38 PM
😓...whew!
on 02-07-2025 03:34 PM
It's okay then in that case you can keep it, I've checked the note on the account. Sorry about all of this. Thanks 😉
on 02-07-2025 03:15 PM - last edited on 02-07-2025 04:51 PM by Gliwmaeden2
Not the Better Value Team - it was Customer Services and Billing. Here is a transcript of the chat:
on 02-07-2025 03:03 PM
If it was a replacement for a fault on your old one, you'll have to return it. Thanks
on 02-07-2025 02:53 PM
Yes. The Better Value team eventually said the email was sent in error and I could keep the router without charge.
on 02-07-2025 02:50 PM
Hi there @spaarks11, just to understand the issue what you basically saying is that you received a replacement router and was asked to return the Eero back or else you'll be charged?
02-07-2025 02:45 PM - edited 02-07-2025 02:48 PM
After 2h30m on chat, I was transferred from Tech Support to the the Better Value team who said that I can keep the router and the email was sent in error. But they cannot send me an email to countermand the original email.
Tech Support did not seem to understand the simple issue, maybe a language problem, and at one point wanted to send round an 'engineer' for £75. The whole thing is bizarre, and not at all acceptable.
on 02-07-2025 12:36 PM
I am talking to them now.
Please refer to my message of 24/4/2025 quote The Gateway Eero has been on Ch106 for the past couple of weeks, and my mobiles are connecing on 5GHz - though I now have extender Eeros in three rooms. I guess we can close this topic now. unquote
I have disconnected the router you want back and the low signal prevails.
on 02-07-2025 10:26 AM
With this instance, our Full Fibre specialists will need to intervene as they will be able to check on your line for any faults that may be impacting your speeds. Kindly reach out to the team using 03451720074 Mon-Fri: 9am-7pm; Sat: 9am-6pm; Sun: closed.
on 02-07-2025 10:23 AM
All three routers are required because there are two areas of low signal, causing my speed to drop from the promised 150Mbps to around 30Mbps or lower in those areas.
on 02-07-2025 08:18 AM
I understand however you do not need all three routers which is why you received this email yesterday. You need to return the one that is requested. Please ensure that you check the sticker so that you can return the one that has the listed serial number.
on 01-07-2025 05:53 PM
Yes. I have three in total, which are all in use.
on 01-07-2025 05:22 PM
Please confirm if you are currently using the router that you were asked to be returned? and how many routers do you have in your possession?
on 01-07-2025 05:16 PM
part
