Router power supply broken following local power outage this morning
mk123
Chat Champion
Message 10 of 10
Hi, my local area had a power cut this morning - the power went out suddenly then came back two hours later. This appears to have broken the router power supply unit, as per Loss of wi fi after power cut - TalkTalk Community. Please dispatch a new power supply for Sagemcom FAST 5464 Router, or if this is not possible, a replacement Sagemcom FAST 5464. Thank you
9 REPLIES 9
Message 1 of 10
Please note I won't be able to run checks for you on my end hence why I'll need you to call or chat in, once you do the issue will be looked into as soon as possible. Thanks
Message 2 of 10
I don't want to do that please. The phone and live chat teams always take ages to answer, and often can't understand the problem, and won't be able to view the link I've sent you, which gives all the information needed - your routers can't handle power outages, this is a known issue. Please can this just be dealt with by someone on here. Thanks
Message 3 of 10
I'll need you to contact our full fibre team so they can run diagnostics on this and have a replacement sent out if required. Thanks
03451720074
Opening Hours:
VOICE - Mon-Fri: 9am-7pm; Sat: 9am-6pm; Sun: closed
https://community.talktalk.co.uk/t5/FutureFibre/bd-p/FutureFibre
Message 4 of 10
Thank you, allow me to investigate.
mk123
Chat Champion
Message 5 of 10
No physical damage. Sorry which checks? The thread Loss of wi fi after power cut - TalkTalk Community describes the issue - my router has the same symptoms
Message 6 of 10
Please note that checks are required in order to pick up the fault and send out a replacement if required. Please confirm if the router has any physical damage? Thanks
mk123
Chat Champion
Message 7 of 10
Also please note we require the new version of the router with VoIP phone port
mk123
Chat Champion
Message 8 of 10
hi, yes
siphosethu-TT
Message 9 of 10
Hi there @mk123, please confirm if you are currently at home. Thanks
