VoIP not working
CherryPicker9999
Message 8 of 8
I upgraded to TalkTalk Full Fibre last Friday with an Open Reach connection (TalkTalk will not provide VoIP on City Fibre lines in the area, unlike Vodafone).
The "landline" phone is plugged in to the router.
VoIP does not work.  If I call my own number, I get the message:
"This person's phone is not currently available."
I rebooted the router and there is no difference.
Any idea what the issue is?
(On my mum's home her Vodafone VoIP worked immediately on install).
7 REPLIES 7
Message 1 of 8
Thank you so much for the support @KeithFrench
Hi there @CherryPicker9999 and thank you for updating us the fault has now been fixed.
CherryPicker9999
Message 2 of 8
Yes it is as expected.
TalkTalk told me there was a network connection issue at their end since Wednesday and their engineers are working on it.
It appears to have been resolved, as my phone now rings.
Thanks for your help.
Message 3 of 8
Hi @CherryPicker9999
Thanks for that. Assuming you have the landline connected to the Phone port on the back of the Hub 3, that should be all you have to do. However, a simple check will see if it has registered or not. If you now log into the router. On the initial page, click on the Digital Voice tab on the left. On that page, it should show the Connection Status as Online and display your phone number (minus the initial 0) below that:-
Digital VoiceDigital Voice
Message 4 of 8
TalkTalk Wi-Fi Hub 3
© TalkTalk 2025
Firmware Version: SGEK10004A00
Message 5 of 8
Thanks for your assistance, @KeithFrench.
Message 6 of 8
Assuming that you have the Sagemcom WiFi Hub 3, please open a browser and go to it's log in page of 192.168.1.1 (unless you have changed this IP address. If you look at the bottom of the page, what firmware version is it running?
nambuso-TT
Message 7 of 8
Hi there @CherryPicker9999. I am very sorry to hear this. As you have a future fibre package please contact the future fibre department using the below number so that they would be able to look into this for you.
Contact Number: 03451720074
Opening Hours:
VOICE - Mon-Fri: 9am-7pm; Sat: 9am-6pm; Sun: closed
WEB MESSAGING - Mon-Fri: 8am-9pm; Sat: 8am-7pm; Sun: 9am-7pm
Alternatively, you can use the live chat link:
https://community.talktalk.co.uk/t5/FutureFibre/bd-p/FutureFibre
