on 11-12-2024 08:45 PM
since having full fibre installed a week ago our home phone will not allow anyone to ring us just says its not available.
I dont seem to be able to get through to anyone at talktalk its pretty useless all i seem to get is loads of logging in proceedures which i find very frustrating WHY IS THE NO PHONE NUMBER SO I CAN TALK TO SOME ONE !!!! talk about talktalk what a laugh.
on 12-12-2024 07:32 AM
Hi Dave,
I'm sorry to hear this. Are you using the Wif Hub 2 router with the voice port on the back or an eero with a separate digital voice adapter please?
We'll then look into this further. Please do not post this information on this thread. Once you've updated your profile please post in your topic to confirm it's updated.
on 11-12-2024 08:59 PM
Our full fibre products are Data Only, so you don't need a landline.
That means superfast Wi-Fi without a phone line.
Our Full Fibre 150 to 900 plans come with the award winning Amazon eero 6 router, powered by Wi-Fi 6 technology .
Plus, our expert install means you get the best connection from day one.
Just remember, you may still need a landline for important services like burglar alarms or home help alarms.
on 11-12-2024 08:55 PM
Did you request the phone to continue as services are either with or without the phone?
If you ordered the phone it will be via VOIP and depending on the router you have, you either plug the phone into the router directly or you need an adapter you should have been sent
The phone will no longer work plugged in as it was.
You are in the staff's queue for a response.
For a quicker reply can you please ensure you have your personal information up to date in your profile including your TalkTalk landline phone number so your account can be traced. Link here - https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profile:personal-info
You can also add your account number in the private notes field, which only you and the support staff can view.
Please post back when done.
Thank you
For info to contact by phone, try phoning 0345 172 0088
Opening Hours can be found here - https://community.talktalk.co.uk/t5/Articles/How-to-contact-TalkTalk-Broadband/ta-p/2230529#
