Home Phone
CALLER DISPLY SHOWING WITH HELD NUMBER
JALNA-ROBERT
Message 3 of 3
ALL INCOMING CALLS, LAND LINE OR MOBILE SHOWING WITHHELD NUMBER.  HELP!!!
Message 1 of 3
I'm sorry for the delay. Does Caller Display show as active when you log into your My Account? If it does then could you try removing this in your My Account, waiting 4 hours and then try re-adding Caller Display again please.
Message 2 of 3
Please do not SHOUT as using capitals is seen as bad manners on forums.
Thank you.
You are in the staff's queue for a response.
For a quicker reply can you please ensure you have your personal information up to date in your profile including your TalkTalk landline phone number so your account can be traced. Link here - https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profile:personal-info
You can also add your account number in the private notes field, which only you and the support staff can view.
Please post back when done.
Thank you
