Home Phone
Connecting landline to new fibre router
cmcpne1
Message 4 of 4
My new talk talk digital fibre router is up and running but none of the ports on the back fit my old BT home phone   Where do I get the correct connector from or do I need a new DECT phone?
F.mcgaahan
3 REPLIES 3
Philile-TT
Message 1 of 4
If you are using a Wi-Fi Hub 2 and Wi-Fi Hub 3 the ATA port is built into the router. If you are using an eero an adapter is provided. This needs to be connected to the eero to allow a home phone to be plugged in.
Phili
cmcpne1
Message 2 of 4
Yes my package includes landline service.
F.mcgaahan
Message 3 of 4
Did you specifically request a phone line and to keep your phone number?
If so the adaptor should have been ordered at the time. I know there was a job keeping up with demand recently though so it may be delayed.
If you can let us know staff will be able to look into for you.
For a quicker reply can you please ensure you have your personal information up to date in your profile including your TalkTalk landline phone number so your account can be traced. Link here - https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profile:personal-info
You can also add your account number in the private notes field, which only you and the support staff can view.
Please post back when done.
Thank you
