on 25-09-2025 04:08 PM
I am having a issue specifically when trying to call any number on the MTN network in South Africa, I have the international calls boost and calls to other South African numbers work ok.
Is there a known issue with this? It used to call through ok. Now it rings and then the line goes silent with the receiving person not having it ring on their end.
on 13-10-2025 02:44 PM
Thank you so much for confirming this, I have escalated this for you to my manager and I will be able to get back to you as soon as I receive a respond.
on 13-10-2025 02:42 PM
It just rings and then goes off, the people on the receiving end's phone doesn't ring.
on 13-10-2025 02:39 PM
What message do you receive when you attempt to call, or does the call gets disconnected?
on 13-10-2025 02:30 PM
Yes, it was just MTN but now it seems to be all networks.
on 13-10-2025 02:28 PM
Just to confirm, have you tried to call the other networks?
on 13-10-2025 01:50 PM
Hi @agm2502 I will check this for you.
on 12-10-2025 04:06 PM
It doesn't seem to be working with any South African numbers now, not just MTN, is anyone else struggling to call South Africa?
on 25-09-2025 04:31 PM
I understand. As you have mentioned that you are currently having issues when calling the MTN network, I will strongly advise for you to get in touch with the provider directly.
on 25-09-2025 04:20 PM
This has been going on for about 2 weeks now.
on 25-09-2025 04:18 PM
@agm2502, thank you for making us aware of this. If I may kindly check, have you noticed the matter today?
Note: There could be a problem with MTN, as South Africa has experienced heavy rains over the past few days. This may have impacted ISP networks. I strongly recommend waiting a bit and trying to make the call again tomorrow.
