on 17-02-2026 10:19 AM
Good morning, my landline has developed a problem, it has a lot of background noise and is difficult to hear someone talking, they also can't hear me very well as voices fade in and out. Could someone please run some checks on my line to see what the problem is. Thank you.
on 17-02-2026 03:06 PM
You are most welcome I hope you enjoy the rest of your day.
on 17-02-2026 03:04 PM
Ok, Thank you.
on 17-02-2026 02:56 PM
The answer to this will be determined after the engineer visit as they will come and review everything that is related to the fault.
on 17-02-2026 02:51 PM
Now that the checks are complete and an engineer will be coming, can you tell me if the firmware on my router is still able to be updated or is it too old. I looked earlier and it's an HG633 on hardware version H.1.01 and software version v1.15t ive had it since about 2015.
When i checked a few hours ago it said the connection duration was 10 hours which means it must have cut out during the night as i last restarted it a few days ago?
on 17-02-2026 02:50 PM
An engineer has been successfully booked, is there anything else I can assist you with?
on 17-02-2026 02:47 PM
Line testing reveals an issue on your line that needs to be fixed by an Openreach Engineer. The engineer will investigate, typically this will be completed within the next 2-3 working days.
Openreach will contact you via a text message with details of the engineer working on your fault on the day the work begins. This includes when they are travelling and when they start working to resolve the fault.
This is a non-appointed visit, which means they'll only be working on the Openreach equipment between your home and the exchange. They will confirm once they have completed their work.
Assuming the problem is outside of your property, the engineer won't need access. However, if the engineer doing the investigation determines that access to your property is necessary, you will be informed via SMS or email and asked to schedule a time that works best for you. If this occurs, we advise getting in touch with us right away to book the engineer appointment.
on 17-02-2026 02:40 PM
Thank you, yes that's great I'll add my mobile number to my profile as the landline calls quality is pretty bad.
17-02-2026 02:35 PM - edited 17-02-2026 02:36 PM
We're booking an Openreach engineer to investigate any issues within the network that may be affecting your service
The engineer is unlikely to need access to your property, so you don't need to be home and if this is confirmed as a fault in the network by the engineer won't be charged.
If the engineer can't find an issue in the network, they may need access to your home to complete further checks, they will try to call and arrange this on the contact number you have provided.
If they can't reach you, don't worry, you will receive a text from us to arrange for an appointed engineer to visit your home.
Please note that terms and conditions for an appointed engineer differ so please pay attention to this if your engineer type changes.
Do you understand this information?
on 17-02-2026 02:19 PM
The checks are still in process it may take a while before we pick up what the fault it. I kindly ask for your patience.
on 17-02-2026 02:15 PM
Have the checks shown what the fault is?
on 17-02-2026 02:01 PM
Thanks for your response.
on 17-02-2026 01:54 PM
Yes, they look exactly the same. I'm plugged into the downstairs one which is the master socket.
on 17-02-2026 01:53 PM
We are running checks to make sure the issue is fixed. You mentioned earlier that you have 2 sockets are they exactly the same?
on 17-02-2026 01:46 PM
Hi, Is my phone line going to be fixed?
on 17-02-2026 01:24 PM
Thanks I appreciate your effort.
on 17-02-2026 01:18 PM
There is no lower front plate, it all comes off in one piece. Behind it there isn't a test socket. I've tried uploading a picture but it generates an error.
on 17-02-2026 01:10 PM
To access it, please do the following:
This bypasses your internal wiring so we can check whether the fault is on the line or inside the property.
Let me know once you’re connected — I’ll continue the tests from my side.
on 17-02-2026 01:03 PM
I’ll take a look at this. Thank you for your patience.
on 17-02-2026 12:59 PM
I've unscrewed the faceplate, there is no test socket on this type of socket Non-NTE
17-02-2026 12:54 PM - edited 17-02-2026 12:57 PM
Could you please disconnect everything connected, take off the faceplate, and connect directly to the test socket? I understand you may not be able to respond right away, so please take your time. I’ll wait until you’re able to get back to me. Thank you.
