24-10-2024 12:08 PM - edited 24-10-2024 12:14 PM
Today both my phone connection and Internet are dreadful.
Trying to make important calls to sort out muddles made by utility companies.
The line appears to be fine for a few minutes and then crashes - I literally asked the E.on Next lady if she had dropped her phone.
We tried on the smartphone and the call suddenly lost wifi calling and crashed too. It simply stopped.
I called back on the landline and got a bit further, but the call collapsed into the equivalent of "snowflakes" on an old telly, i.e. crackle, crackle, crackle.
It recovered enough to finish what we were trying to do.
I've been out and about dealing with other jobs and have come back to my router repeatedly losing the Internet connection.
I can't fall back on Three....
The internet keeps disconnecting. Is something happening with the firmware? Check for repeated loss of connection this morning, please.
on 19-11-2024 09:53 AM
Just had to accept a doctor's phone appointment and the earliest they can do is the morning of 27th. Will need to have wifi calling fully functioning and the option of the working landline, so:
only the afternoon of 27th now available, must be after 1pm, if the engineer is needed, @Debbie-TalkTalk.
on 19-11-2024 09:40 AM
Hi @Gliwmaeden2
I will check the connection stats in the morning and I will post back here.
on 19-11-2024 09:33 AM
I can keep the day clear if I know in advance, but only Wednesdays.
Will you check data later in the week to confirm the next step, @Debbie-TalkTalk ?
on 19-11-2024 08:50 AM
Hi @Gliwmaeden2
I've tried the data port reset and optimisation again. If the connection continues to drop out then I will look to book the engineer for 27th. Are AM and PM appointments better?
on 19-11-2024 08:39 AM
Well, if the settings don't hold, they do need to do something more thorough including lifting the lid on places in the street between here and the exchange.
I've outlined the history of their investigations above, so please pass that on to them, as this is not just a recent development but something to do with the line for years.
I got several lengthy "connected without Internet" periods yesterday on one phone, but yet on the same phone there was no interruption in BBC Sounds overnight this time. Quite bizarre.
The ONLY day of the week I can book a visit is on Wednesdays (not tomorrow) so 27th would be the soonest it could be, @Debbie-TalkTalk.
on 19-11-2024 08:12 AM
Morning @Gliwmaeden2
Would you like me to arrange an engineer visit or would you like me to try one more data port reset and line optimisation first?
on 18-11-2024 04:49 PM
It was received on April 29th this year, going by delivery emails, @Debbie-TalkTalk.
The annoying thing is that the last time an engineer visited, he simply unplugged the extension to the upstairs socket and blamed intermittent faults on my wiring which is built into the building.
So I have not had the use of my computer all this time, as there is no space to fit it downstairs. It could be that my internal wiring was fine all along.....
The preceding engineer mentioned sending a more qualified one to look under entrance points in the street and that never materialised.
My Connection has shown a fault therefore for 2 or 3 years that's been intermittent, and manifested mostly as crackles or people being unable to hear me at all on the phone.
The internet being affected has been more noticeable in recent months. [ I have hardly used the phone since removing the boost when it got expensive, so haven't been able to monitor it's performance that much.]
But, basically, other than the engineer before that, who did crawl around in the streets and did something with crimps, if I remember rightly, so managed to revive the speed of the line wonderfully, nobody has ever stuck at the job to get it 100% sorted in years!
on 18-11-2024 01:32 PM
Hi @Gliwmaeden2
If the connection is still dropping with the router and filter at the test socket then the next step will be an Openreach engineer visit to the property.
How old is your current router? I think we sent one recently?
on 18-11-2024 01:27 PM
@Debbie-TalkTalk, another Connected without Internet incident about 12.40pm today.
Anything being done to investigate the low SNR?
All apparatus has been in the test socket since last week.
on 18-11-2024 09:38 AM
Yes. I haven't changed anything since simply switching the microfilter last week, @Debbie-TalkTalk.
Do the engineers need to take another look if there's this SNR problem?
on 18-11-2024 09:35 AM
Hi @Gliwmaeden2
I've checked the connection stats and the SNR is still dropping low and I can see re connections.
Is the router still at the test socket with the new filter?
on 18-11-2024 09:22 AM
The 3.30am drop out occurred (or rather BBC Sounds stopped again then, but it might be the battery saving or something, so I still have more detective work to do).
But there have been a few incidents of "connected without Internet" showing, so one phone is fine while the other drops. So wifi continues to function but not always for both phones at the same time, @Debbie-TalkTalk.
I sometimes cross refer information between my phones, so do need to have them both receiving the signal reliably. It comes back if I switch off WiFi on the offending device and then back on again, so it still can find wifi.
Interference?
Haven't been making or receiving landline calls so can't check that yet.
on 18-11-2024 09:03 AM
on 15-11-2024 08:59 AM
Thank you @Gliwmaeden2
I've optimised the connection too and the SNR has increased.
I will check in again with you on Monday to see how the connection has been over the weekend.
on 15-11-2024 08:53 AM
That's it set up with the (much smarter looking!) microfilter now, @Debbie-TalkTalk.
on 15-11-2024 08:41 AM
Hi @Gliwmaeden2
I can now see the connection stats and the SNR is dropping low again.
Please can you connect the new microfilter to the test socket?
15-11-2024 08:32 AM - edited 15-11-2024 08:33 AM
No, the router is NOT switched off.
I have wifi right now.
Are there issues at your end reaching it?
As I said, absolutely nothing has been touched all week since putting it in the test socket. @Debbie-TalkTalk.
on 15-11-2024 08:29 AM
Hi @Gliwmaeden2
Sorry to hear this.
The line test is clear - No faults detected.
Have you switched the router off this morning?
on 15-11-2024 06:16 AM
@Debbie-TalkTalk, could you possibly check at your end for dropouts in the connection?
After a few nights where it seemed fine, the radio had stopped again in the wee small hours, Friday am.
BUT, more seriously, a pupil needed to phone in when stuck in traffic and my landline had impossible static on it. I texted to tell them to try again and it was perfectly fine the second time.
They were really shocked at the awful noise the first time.
This was NOT after changing anything since the start of the week (so still plugged in at the test socket and not yet switched the microfilter).
Please could you test the line again to see if it's registering a fault as well as any disconnections?
on 12-11-2024 08:04 AM
Oh good 🙂
Yes it's always handy to have spare microfilters around just for testing.
