New TV hub
Moorelace
Message 3 of 3
Installed new TV hub but unable to access players other than iPlayer.  Checking apps in settings and only iPlayer shows.  Reinstall hub?  How?
Message 1 of 3
How are you getting on?
Message 2 of 3
Do you have the aerial attached as done apps need an aerial to confirm your region, such as ITVX and C4.
To reset the box, go to the cog icon, and factory reset is under one of the headings there
Hope this helps.
