Settings stuck on to tv screen
Freda!
Newbie
Message 2 of 2
I accessed settings they came up on the screen and now I can’t get them off the screen. I have new hub and remote which I don’t like
1 REPLY 1
Message 1 of 2
I've had this too and the only way ive found to clear it is to disconnect the box from the mains and then power up.
The home and back buttons don't clear this when I've tried.
