TV HUB/USB
griffin100
Message 2 of 2
I have a  tv hub which i have had for 6 months, annoyed that it has no record feature but looking at the specs for the hub , it says if u have a usb stick you can insert in the hub and  then it can be used to record a program into the usb, well  i have a usb stick and put it into the hub and a while later i got a message on my tv screen that the usb had been accepted but still no idea how this works, anybody else had this problem and if so please help.
1 REPLY 1
Message 1 of 2
You can't record on the Hub.
You could on the 4k Netgem box, which is no longer available. Did you perhaps read this thinking it was relating to the Hub?
The USB is for playing back your mp3 files or viewing photos.
