TV HUB
Gemma1/Gypsy2
Message 2 of 2
I have just received my TV HUB - I still wish to record programmes as I do not want to play and watch the adverts but fast forward through them - also I record radio programmes particularly radio 4 but I cannot see that this is possible . Is it possible to still record programmes please with this system?
1 REPLY 1
Message 1 of 2
No, this box is non recordable. TalkTalk no longer provide recordable boxes.
If you still have your recordable box, you can continue to use this and the Hub together, but will require a separate aerial connection to both. Splitters are reasonably priced and can be obtained from local electrical dealers at markets and supermarkets
