TV compatibility with Dolby UZW4054
Jimbo151
Message 2 of 2
 Is my new Dolby Youview box compatible with a Hisense 50 Inch 50A6KTUK Smart 4K UHD HDR DLED Freeview TV
1 REPLY 1
Message 1 of 2
Should be but you may need to check settings on your TV.
Have you set up the box? The TV Hub searches and sets itself up based on what it perceived to be the correct settings.
I had to adjust my TV picture settings to mute the colours, but that is a personal choice.
