new tv hub
ragmansdog
Message 2 of 2
have just got tv hub how do we save any progs we want or are they all on catch up and if so how far back does it go
1 REPLY 1
Message 1 of 2
You can't record programmes on the hub.
You can view past programmes using the guide if available using the guide, or by opening a catch up apps such as iPlayer and playing the programme.
These will then be stored in MyTV and act as a short cut to the next episode in the series.
