26-11-2024 05:13 PM - edited 26-11-2024 05:15 PM
After agreeing to sign up for Fibre 150 voice for 18 months and reading up on the Eero 6 having only two Ethernet ports, I am worried we won’t be able to use two of our computers as they only connect to the internet via Ethernet cables.
If one of the two Eero 6 Ethernet ports is used to connect to the Openreach modem and the other for the phone, there won’t be any more available Ethernet sockets.
Or can I continue to plug in the PowerPlug to send the internet around the house and plug in the grandstream for the phone into one of the powerplugs?
on 27-11-2024 09:08 AM
Hi @MAISIE6
@Anonymous has asked me to help you. All you have to do is to purchase a cheap gigabit switch like this example:-
Then connect one port of it to the spare Ethernet port on the eero, leaving you four ports for your wired devices. One of these would need to be used for the Grandstream. If that still is not enough ports, buy an 8 port or larger version.
on 27-11-2024 07:07 AM
