WiFi booster
Abbie13
Message 8 of 8
Can anyone recommended a wifi extender or booster please? My son is struggling with weak signal upstairs. We have the eero downstairs and I need something to help with the signal in his room but don’t want to spend a fortune.
7 REPLIES 7
Message 1 of 8
WiFi interference is easy to check, if you want to. Where the router is concerned, is it near any other electrical equipment, mirrors or fish tanks etc that could disrupt the WiFi signal?
Message 2 of 8
Yes just one. Think I need to move my router
Message 3 of 8
Thank you
Message 4 of 8
Thank you for your help
Message 5 of 8
Hi Abbie13
Thanks Keith 🙂
Sorry I forgot to add
KeithFrench is one of our valued Community Stars and can help with a range of issues related to wireless and networking. At times he may ask you to send him test results via a Private Message to help analyse/diagnose an issue.  Although Keith does not work for TalkTalk, he very kindly shares his time and knowledge to help with others.
If you need further help or, if we need to take any details such as personal information about your account like phone numbers, account numbers etc.  one of the TalkTalk team will jump in and help out.
Message 6 of 8
Hi @Abbie13
@Debbie-TalkTalk has asked me to help you.
The only truly correct way to extend an Eero is to use another one so that they form a mesh network. However, before going down that route, it would be sensible to check for WiFi interference.
However, other factors should be investigated first. When this happens, what is the status displayed in the app for the internet connection? Do you have any wired connections & if so, how do they perform?
The next stage involves sending out a guide to you to help you get me some important diagnostic results so that I can analyse them for you and recommend changes to your router configuration to solve them.
Whilst the Eero is supposed to manage Wi-Fi interference, if this is very bad, particularly in the 2.4GHz band, then it cannot do anything about it, no router can. The same goes for any router at that point. Other things that may then need to be investigated are its location within your property and the WiFi bands that you use.
Message 7 of 8
Hi Abbie13
Do you have just the one eero?
@KeithFrench Could you offer some advice please? Keith provides really great advice on improving wireless performance.
