Firmware Update
SuperflyForever
Message 121 of 121
Hello there, I saw after some searching that people were requesting an update pushed to their router. We recently upgrade to Fibre 65 and despite the offer saying we would be provided with a new router, we didn't get one sent. So instead we bought one but it seems that the firmware according to some posts I gleamed through on the forums here that it needs an update.
Over the past few weeks since having the new router, we will have had inconsistent disconnections. It will sometimes happen multiple times in an hour or once every 24 hours. I saw people saying it was some DNS issue, but before I went messing around with that by myself, I was hoping to get some proper support before I go ahead with that.
The current router firmware is #SG4K10002816.
120 REPLIES 120
Message 41 of 121
Message 42 of 121
Oh, wonderful. Thank you for dealing with this so quickly. It means a lot. I will get back to you when it arrives and let you know the outcome.
Thanks again.
Message 43 of 121
Hi SuperflyForever
I have ordered a replacement microfilter, please allow 48hrs for this to arrive.
If you remove the faceplate from the master socket, then you can connect the new filter directly at the test socket.
Thanks again.
Message 44 of 121
That would be great. Thank you. The one we have sockets into the wall, embedded in, I assume that doesn't matter.
Message 45 of 121
Hi SuperflyForever
I can send you a replacement microfilter, would you like me to arrange this?
Message 46 of 121
Hello again, sorry. When I wrote to you previously, I forgot to write that I hadn't tried a new microfilter because we didn't have a spare. Was in a bit of a rush while writing that. I apologize.
Message 47 of 121
Thanks for confirming. Would it be possible to test with a different microfilter just to rule this out? If this is still happening with 2 different routers and microfilters at the test socket then the next step would be to arrange an engineer visit to the property.
Message 48 of 121
Hello Debbie. I haven't tried a new microfilter. When the technician was here last year, he replaced it with a new one as the one we had was faulty. We were also sent a new router, which I believe is a 'Sagemcom 5364'.
I'm not sure why the phone ringing and knocking out the internet has happened again, as it's been fine for the past about 7ish months. It doesn't always knock the internet out when the phone rings, but it's still more likely to happen than not.
Message 49 of 121
Hi SuperflyForever
I've completed 2 different line tests and both are clear - No faults detected.
Have you tested with a different microfilter at the test socket?
Which router are you using? (make and model)
SuperflyForever
Message 50 of 121
Hello again. I hate to be an absolute pain again, but for about the past two months or so. The internet has been suffering a similar issue to what used to happen last year. Sometimes when the phone will ring, it knocks out the internet. It used to do this before the technician but a technician did fix it, but I guess it's just come back again. We've tried unplugging phones around the house but it's not had any success. Not sure what the issue is this time, maybe it is something outside like last time.
Thank you.
Message 51 of 121
It's quite alright since it was a whole mess of issues that required lots of different solutions. Take care! Hopefully, you won't be hearing from me again for a while, haha!
Message 52 of 121
Ah that's very kind thank you. I'm sorry it wasn't resolved in the first instance for you. Stay safe too 🙂
Message 53 of 121
Thank you. I'm very thankful for all the help you and your team did to get this issue sorted out. Was a long road with a lot of headaches, but I'm glad that everything was sorted out. Can't thank you all enough. Hope you all stay safe and cool during the heat.
And thank you again, you are all absolute stars.
Message 54 of 121
I'm really glad to hear this and thanks confirming 🙂 Please let us know if you need any assistance with anything.
Message 55 of 121
Hello Michello, It's been pretty much good, yes. Had a weird hiccup the other day where it dropped out for a couple of seconds. But can't say I have noticed any issues like before. So it looks like everything is all good for now.
Thanks!
Message 56 of 121
Has the connection been ok since your last post?
Message 57 of 121
Thank you for doing that!
Message 58 of 121
OK I'll start the upgrade now, please don't switch off your router
Message 59 of 121
Sure, that's totally fine. Thank you.
Message 60 of 121
Hi SuperflyForever,
That's great news. Do you want me to update your firmware now, it can take up to 15 minutes to complete?
