Internet speed has gone down two days on the trot!
jwatson
Whizz Kid
Message 31 of 31
Hi, my internet is not the fastest where I am, but I usually maintain a steady 20mb download. Tuesday morning around 2am, there was some activity on my router log, and the speed went down to 18mb. Then this morning at 2am, same again, this time down to 16.5mb!
03.08.2022 02:40:04InfoXDSL
VDSL connectivity is up port 1
03.08.2022 01:58:24InfoXDSL
VDSL connectivity is down port 1
Last time this happened, I think the profile was reset (I think). Can I have my minimum of 20mb back please?
JW
30 REPLIES 30
Message 21 of 31
I have used both! The cable comes in through a window, which is where the socket is, I have no extensions! I live in a small bungalow!
Skynet_TX
Message 22 of 31
Is that using the test socket, or just in the regular socket ?
jwatson
Whizz Kid
Message 23 of 31
OK, it's finally come back up, hours later... but still very slow, 16.5mb download!
Skynet_TX
Message 24 of 31
If the master phone socket has a test socket it would still be worth testing the router in there, as sometimes the socket faceplate can develop faults, so trying the router in the test socket will eliminate that as a possibility.
Message 25 of 31
Yes, the online tools say all is OK! The cable comes into my window, and that's it, so no cableing involved!
Skynet_TX
Message 26 of 31
Hi @jwatson,
It would be worth going to the Service Centre to run a connection test on your line, this will indicate if there is currently a fault affecting your service. You can also access this from the ‘My Account’ site.
If your master phone socket has a test socket then you could also try the router in there (via a microfilter), that would then eliminate any of the phone wiring in your home as being a possible cause of the problem.
The TalkTalk Support Team on this community will be able to help, they will hopefully be able to respond to this post tomorrow.
jwatson
Whizz Kid
Message 27 of 31
My internet is totally down now! Orange light flashing on router for ages (hours)!
JW
Message 28 of 31
This will start a new session with the exchange, and we can see if DLM will start to raise the profile back up.
jwatson
Whizz Kid
Message 29 of 31
Hi Karl, thanks for the reply. OK, the router has been powered off and unplugged for 45 minutes, it's just come back up again now, download speed is still only 16.5.
JW
Message 30 of 31
All usual tests on your line are clear and no issues are showing.
Can you power off the router for 30 minutes to allow a new session to start then we can see if the profile will increase over the next 48hrs.
