Router keeps disconnecting and connecting again.
Veiled
Message 22 of 22
Hi all,
I am having some issues with my router as it keeps disconnecting ( Beeping orange, orange white and white again intermittently.)
I have moved houses and my connection got live at 25th, first few days I had no issues at all but past few days have been frustrating as I cannot do my work at all. The router was replaced few months ago and had no issues until now. My connection speeds are fine when it is working but with these constant drops I cannot do much. I have raised a fault but this is still in progress I need some help getting this fixed as soon as possible. I was told this could be cause of optimisation but it should not disconnect me.
Using Black wifi hub and on 65 Fibre. I have tried resetting the router by pressing 20 seconds with a pin on the back of the router.
Fault Number: REP-13210018
Hope to hear from you.
Many thanks,
Veiled
21 REPLIES 21
Message 1 of 22
Hi Ian,
I'm sorry to hear this. Please can you create your own topic and we can look into this further for you.
IanMalpass1
Message 2 of 22
Did You get it sorted ?
Mine is doing the same but trying to contact TT is a pain & its as if NO-ONE IS LISTENING!
What was the fault?
Message 3 of 22
Thanks for letting us know and please let us know if you need any further assistance.
Thanks 🙂
Message 4 of 22
Hi Karl,
I have disconnected from test socket and reconnected to the Master socket and been testing for a week with no issues.
I suspect optimisation caused all these unfortunate issues.
At the moment everything is working as expected with nothing to report back.
Message 5 of 22
How are things so far, is the connection remaining stable ?
Message 6 of 22
Ok thanks for the update and please let us know how you get on over the week.
Message 7 of 22
Morning Michelle,
I am still connected to the test socket line and only had one disconnections over the weekend.
I will be switching back to the master socket tomorrow and observe this week.
Message 8 of 22
Just checking back in to see how you've found the stability over the weekend?
Thanks 🙂
Message 9 of 22
Hi Chris, so far so good with the test socket. Can I continue to be connected to this socket or should I switch to master socket and observe to find the root cause?
I do not think I have experienced any loss of connection today.
Message 10 of 22
Message 11 of 22
Hi @Chris-TalkTalk
I will be observing this rest of the day and will put an update by the evening or tomorrow.
Message 12 of 22
Hi Veiled,
How has it been since your last post?
Message 13 of 22
Hi @Chris-TalkTalk
The issue still remains. I have connected to the test socket to observe and within 10 minutes the router disconnected and reconnected three times.
I think there is an issue with the phone line? Would be great to have some insight on what needs to be done.
I will be connected to the test line and keep on observing.
Thank you,
Message 14 of 22
OK thanks. I'd see how it goes and if you do experience any further disconnections then it would be worthwhile testing at the test socket to make sure that your internal wiring isn't causing any issues
Message 15 of 22
Hi Chris,
There is 4 I believe but the router is only working with the master socket. Today I have not experienced any issues so far no disconnection/reconnection. Perhaps something to do with optimisation?
If you need me to connect to the test socket please let me know.
Message 16 of 22
Hi Veiled,
Thanks for adding your account number. Is you router currently connected to the test socket (the socket behind the master socket faceplate)?
How many telephone sockets do you have in your home?
Message 17 of 22
Hi Michelle,
Yes, the phone number is correct and I have updated the private notes with the account number.
Message 18 of 22
I'm sorry to hear this. Just to confirm, is the telephone number in your Community Profile correct? Please can you add your account number to the Private Notes section of your Community Profile. Please do not post any personal information on the Community.
Message 19 of 22
Thanks @Veiled good info for the team tomorrow morning.
Message 20 of 22
Hi @Divsec
The router is plugged to the master socket with openreach mark. I do not use landline phone at all so I am not sure if there is a fault with that but the lady I spoke on livechat said there is no line fault.
