YouView TV Guide not working or slow
Message 49 of 49
@Mmatt , @Pez30 , @Bferen , @Frankafrank , @Rusty_2 , @Glendevonfrank , @Glenda5 , @Cathcol , @SCBierton13 , @Suezz , @Chevy1
Can you all please confirm if you have tried the following :
removing the aerial  = Y/N
remove the ethernet = Y/N
reboot = Y/N
retune = Y/N
Also have you done a factory reset Y/N
If you can also let me know the number of channels you have after a reune, and if you notice this issue affecting a specific channel, or what channel you are watching when you notice this happening.
Please reply just in this thread so I can collate all answers for our Youview contacts.  I'm in direct contact with them currently so can relay info across quickly.
I'll also pin this thread at the top for now so it's easy for you all to find.
48 REPLIES 48
RMurray
Sightseer
Message 41 of 49
I’ve tried these  too no luck - initially i bought a new remote which worked ok for 2 days then went back to slow slow slow slow and impossible to use 😞
Rusty_2
Message 42 of 49
He's managed to do all those and it's just the same
Rusty_2
Rusty2
Maisiejane
Message 43 of 49
I keep rebooting I have not removed any of the leads as I am not very mobile to access the back of the box. Everything is very slow and. It’s  not corresponding with the remote control. This had been happening for about a week ..
Pez30
Repeat Guest
Message 44 of 49
Disconnected everything remote not working.  Tried twice more,  same problem so I still have an issue in fact now it’s worse.
Rusty_2
Message 45 of 49
Hi Karl,
Cant get to my son's until Saturday but will do all that and get back to you after that
Rusty_2
Rusty2
Suezz
Sightseer
Message 46 of 49
Hi Karl, mine seems to be working o.k except for having to load it to switch it on. I did a factory reset when it wasn't working but it didn't do any good just lost all my recordings . Got my fingers crossed it keeps going. Going to try unplugging then switching on to see if that fixes the not starting with the remote but not till the next time I switch it on.
Message 47 of 49
Excellent, thanks for cnfrming, I'll update my list here.
Glenda5
Sightseer
Message 48 of 49
I have tried all of those options.
