A VPN (virtual private network) is a private network away from a public internet connection, meaning that only authorised people can access it. Your access to company systems and software will be through this secure connection, this is ideal for workers away from the work premises as it's completely safe to use as your company will have set up a secure encrypted connection, so it's like being in the office at home.
Your company will have software installed on your machine usually a laptop and you have to log in with your username and password to be able to access the work tools you need to do your job. If you're having any difficulty with your VPN then in the first instance contact your IT department.
If you are having any issues connecting to the VPN then in the first instance it's worth talking to your I.T. department, as we do not stop access to VPNs.
If you find yourself working from home and have to use remote desktop applications like TeamViewer, Anydesk or Remote Desktop Manager, and you have Scam Protection already enabled on your line and you're sure that the service you want access to is genuine, then follow these steps to turn it off;
Our community is here to help 24/7, 365 days a year, pop your question in the community and you never know, the answer may already be waiting for you.
You may find yourself having to work from home over the coming weeks, so we've created some tips for taking care of yourself, staying well and getting the best out of your broadband, for more information check out tips for working from home
