2.4Ghz
slaw99
Message 4 of 4
I have an eero6 router. I need to set the NaimMu-soQB streaming device to use 2.4ghz. This I achieve by pausing the 5ghz connection. The QB then connects to the 2.4Gz but then falls back to 5ghz as soon as the 10 minutes pause time elapses.
Please advise is there a way to force the QB to stay on the 2.4ghz connection.
Rgds
Simon
3 REPLIES 3
Message 1 of 4
Well the AP disagrees with you.
Why does it need to be on the 2.4GHz band anyway,, unless it is a range issue, the 5GHz band allows for the fastest speed. You may be anle to disable Band Steering in the Eero App, I don't know. However, if you can this is likely to adversely affect the performance of the rest of your 5GHz capable devices.
Message 2 of 4
I get that but I don't want the QB on the 5GHZ connection as it requires 2.4GHz to function correctly with other NAIM multi-room devices.
Message 3 of 4
Not knowing this device at all, it is only a network adapter at the end of the day as far as any router is concerned. The Band Steering feature of most WiFi APs is there to move any 5GHz capable device to the 5GHz band, to improve network performance.
