Broadband regularly cutting out
Chris159
Message 30 of 30
My broadband keeps disconnecting. It’s happening several times a week, often multiple times a day. I’ve tried turning the power off and on again, and tried resetting the router but neither makes any difference.
29 REPLIES 29
Message 1 of 30
Hi Chris159
That's great news 🙂
If you do experience any further issues then please let us know.
Chris159
Message 2 of 30
Yeah it does seem to have been better. Don’t think it’s cut out once.
Message 3 of 30
Hi Chris,
The connection appears to have been much more stable over the last 24 hours, have you noticed any improvement?
Chris159
Message 4 of 30
Hi Chris. Just checking in about the connection. Thanks.
Message 5 of 30
Chris159
Message 6 of 30
Yep will do
Message 7 of 30
Hi Chris,
Could you bump the thread tomorrow and I can then check the line history for the previous 24 hours
Chris159
Message 8 of 30
Hi Michelle/Chris. New router has arrived and is now plugged in and set up. How’s the connection looking?
Message 9 of 30
Chris159
Message 10 of 30
Great thanks. I’ll post here when it’s arrived and I’ve set it up.
Message 11 of 30
Hi Chris,
I've ordered the router, it should be with you within a couple of working days
Chris159
Message 12 of 30
We don’t have a spare router. If you could send one that would be great. Thanks
Message 13 of 30
I've re-checked the connection stats now and the connection still looks unstable. Do you have an alternative router that you could test with? If not then we can send a replacement router for testing purposes and a router returns bag so that one of the routers can be returned.
Message 14 of 30
We'll re-check the connection stats first thing on Monday morning and will post back on your topic with an update 🙂
Chris159
Message 15 of 30
Yes that will be fine. Will you get back to me on this thread after the weekend or shall I message you? Just to confirm this is what it looks like now. Is that right?
Message 16 of 30
Thanks for confirming. I've re-run the line test now which is clear. Would it be possible to keep the microfilter, router and phone at the test socket over the weekend so we can re-check the stability to see if this has improved?
Chris159
Message 17 of 30
Hi Michelle. Connected to the test socket now.
Message 18 of 30
Thanks for confirming. Please let us know once the router is connected at the test socket and we can re-run the line test again for you.
Chris159
Message 19 of 30
Hi Michelle. Is it too late to do this? I’ve got some time today I should be able to try the test socket
Message 20 of 30
The NTE5C should have a test socket. I've included a Help Guide below. If it's possible please can you connect the microfilter, router and phone directly at the test socket so we can see if the stability improves.
Your guide to main phone sockets - TalkTalk Help & Support
