Can my neighbours wifi be effecting mine?
Sophhh
Message 12 of 12
My wifi has been very temperamental for the past couple of weeks, it works and then goes through hours of not working repeatedly. I have talked to TalkTalk support and did a hard reset which had my wifi working for a few hours and then it’s gone back to no connection again. There doesn’t seem to be a problem with the line on talktalks end. My WiFi had been working great up until this problem, the only thing I can think it could be is that my next door neighbour (attached house) has recently moved in and had new wifi installed. Can anyone suggest anything as TalkTalk keep telling me to do hard reset and does it work but only temporarily.
11 REPLIES 11
Message 1 of 12
Hi Sophie
Glad to hear that you've seen some improvement. The Fault ticket is still open and showing task in progress so looks like Openreach are still working on this
Message 2 of 12
Hi Chris,
No I haven’t heard from them yet, however my wifi is doing a lot better, only had one blackout yesterday and none so far today. Could it be possible they’ve already been out?
Sophie
Message 3 of 12
Thanks. I can see that this has been logged out to Openreach for investigation, have you heard anything from them yet?
Message 4 of 12
Hi Chris, I have done
Message 5 of 12
Hi Sophhh,
Can you update your profile as Keith as requested and we'll be happy to take a look at this for you
Message 6 of 12
OK I have asked one of TalkTalk's support to pick your thread up and investigate it for you.
To save yourself time, please make sure that your community profile includes your first & last names, Full Fibre account number & if possible an alternative contact number. This can be done by clicking on your Avatar picture and then clicking on "My Settings" followed by:-
Message 7 of 12
I have yes, I’ve also done a hard reset, reset the modem too and it does all work but not for long until it does down again
Message 8 of 12
That sounds more like an issue between the eero and the internet, rather than WiFi reception. Have you tried turning the ONT off for at least 30 mins?
Message 9 of 12
Hi Keith,
Yes please I would really appreciate your help. It is an eero 6 and the model number is: N010001
When it happens the light is red or sometimes it’s still white but just doesn’t work. It is back on again now, but in a few hours will probably go down again, it seems to be better in the day than at night. I don’t have any wired connections, it’s all wireless ones. I’d love for you to send the guide please, thankyou!
Message 10 of 12
Hi @Sophhh
@Anonymous has asked me to help you. Which make/model of router do you have ?
Message 11 of 12
@KeithFrench - would you be able to offer any advice on the wireless connection please?
