Can’t see wifi
awhapshott
Message 3 of 3
Hello, My router is showing a steady orange light, and I can’t even see it to try to connect to it (doesn’t come up to select) it’s been a few days and I’ve tried resetting, on/off and waiting..  out of options really!?
went through the online help and they said it all looked connected fine…   Thanks in advance!
Message 1 of 3
  • Name
  • Telephone number
  • Alternative contact number
Message 2 of 3
Hi @awhapshott
They aim to respond within 48 hours (Monday - Friday) excluding Bank Holidays, but if more urgent you can always try the Service Centre on 0345 172 0088. The posts are responded to in time/date order, oldest first. Please try to avoid posting on here until TalkTalk has responded to you, otherwise, this will just put you further down the queue.
