Company VPN connection issues following Firmware update
osylvesto
Message 3 of 3
I'm Having issues with my VPN at home, it has been working fine until today where it would appear that ive had a firmware update to SG4K100130 and now it wont connect
My IT department have investigated and confirmed that they have had similar reports for other users with TalkTalk as the provider, and confirmed that they resolved the issue by updating the Firmware to another version and is supported by a number of Community threads including one by one of our users
https://community.talktalk.co.uk/t5/Broadband/Company-VPN-Connection-issues-Folloing-firmware-upgrad...
the suggested Firmware update that fixed this issue was SG4K10002828t however When this was applied to my colleagues router it subsequently bricked the device and @Debbie-TalkTalk  was then unable to access this device
the only way to resolve this issue in the end was to send a Howie wifi Blck router which appears to have been preloaded with correct working Firmware
Can someone please look to help me get this device sent out as i cannot work currently
the VPN Type is PPTP and could well be what's been blocked as have this across other providers (Virgin, BT) in the past
Message 1 of 3
Hi osylvesto
Apologies for this.
We will need to make a change to your firmware version, when would be the best time for us to do this?
We advise to leave the router switched on without being rebooted whilst we update the firmware.
Please can you also add your name and TalkTalk landline number to your Community Profile.
Message 2 of 3
I have asked one of TalkTalk's support to pick your thread up and sort it for you.
They aim to respond within 48 hours (Monday - Friday), but if more urgent you can always try the Service Centre. The posts are responded to in time/date order, oldest first. Please try to avoid posting on here until TalkTalk have responded to you, otherwise, this will just put you further down the queue.
