on 12-08-2023 05:36 PM
I have a Talk Talk Super Router HG635.
I have plugged a SSD 2 TB drive into the USB on the router.
It is listed on the router as connected device.
Have eneabled Samba and sharing as per router instructions/prompts.
I cant access the storage device from my Tablet despite it being on the wireless network that the SSD drive is on.
Have I missed something?
on 13-08-2023 03:02 PM
Hi @Confused9
The HG635 router only supports SAMBA or SMB V1, which as @martswain has pointed out is no longer secure. The guidance from Microsoft is never to use it, so don't, that would also be my recommendation. No current TalkTalk router allows connection of an external HDD in this manner anymore due to its insecurity.
A NAS or connecting this drive to a PC & create a share on it is the best way to go these days.
on 13-08-2023 11:26 AM
You need to install an app on the tablet, such as CX File Explorer, which doesn't pester you with ads
https://play.google.com/store/apps/details?id=com.cxinventor.file.explorer
More options: https://tehnoblog.org/es-file-explorer-manager-alternatives/
on 13-08-2023 10:51 AM
Many thanks.
I don't know much about networks so any help would be great.
Do I need to assign a IP address to the drive so that the android file manager can find it?
That's what it feels like, but I am just guessing.
on 13-08-2023 09:55 AM
Not 100% sure on this but as far as I am aware SAMBA is not supported on Android, you may need to download an app.
I have an old HG633 router and a USB connected drive however Windows 10 and 11 updates around 6 months ago stopped all access as the older SAMBA protocols are no longer secure.
Community Star @KeithFrench may be able to advise further when he has a moment.
