FAST 5364 wifi hub - Port Forward or DMZ just can't be set
ronaldtao
Message 7 of 7
I have a FAST 5364 wifi hub, with firmware version SG4K100208.
1. When I tried to add new port forward, it will keeps complains my port number can't have -, but there is never a - in the port number
2. When I tried to add DMZ, it just says it could not complete
6 REPLIES 6
Message 1 of 7
Hi there @ronaldtao, please complete the factory reset as @KeithFrench suggested. Will take it from there afterwards.
Thank you @KeithFrench
Message 2 of 7
Normally, @ronaldtao when you see the error that something wrong happened, you need to do a factory reset on the router. This can be especially true with hardware revision 3 on the 5364; V4 is not affected by this.
Message 3 of 7
I'll escalate the matter for you, I'll get back to you as soon as I have feedback. Thanks
ronaldtao
Message 4 of 7
siphosethu-TT
Message 5 of 7
Please confirm how it goes once you've tried the steps on the link. Thanks
siphosethu-TT
Message 6 of 7
Hi there @ronaldtao, please use the link below to set up port forwarding. Thanks
Set up port forwarding
