Facetime & Whatsapp Calls not running on TalkTalk WIFI
guywatts
Message 6 of 6
Hi Team,
I've had my FTTP 500 Service since July last year - little to no problems.
Recently calls on our Apple Devices using Whatsapp & Facetime have failed to make calls out or recieve them on the TalkTalk Wiif. They work perfectly on the 4G/5G Networks but have stopped working on the wifi.
I have disabled Home Safe and the Scam protection to see if that has made anything better, but it hasn't.
I found this thread: https://community.talktalk.co.uk/t5/Broadband/whatsapp-not-connecting-to-wifi/td-p/2653703
Which sums up my issue and sounds like an adjustment made by one of the TT Team would fix my issue.
Could i ask for this to be looked into?
Thanks,
Guy
5 REPLIES 5
Message 1 of 6
Hi Guy
I can try a different firmware version to see how the connection compares. Would you like me to update this?
We advise to leave the router switched on without being rebooted whilst we update the firmware.
Message 2 of 6
Hi Michelle,
Sorry i thought i had replied!
It's the following - I have reset the router and power cycled:
TalkTalk Wi-Fi Hub
version SG4K100136
Message 3 of 6
Ok, thanks for trying this. Have you also powered down the router for a full 30 minutes as this will reset the current session and can sometimes help. What version of firmware is currently on the router?
Message 4 of 6
Hi Michelle,
yes I have, all reset but to no avail sadly
Message 5 of 6
I'm sorry to hear this. Can I just confirm, are you using the Wifi Hub? Have you tried factory resetting the router and then re-setting this back up again?
