Fibre 150 - Can I upgrade the factory box?
on 02-02-2022 01:27 PM
Message 18 of 18
I was wondering if I could upgrade my factory router just ive noticed the signal stregth on them isnt great and the Bt engineer who installed it did reckomend buying a third party router to see better performances. but he mentioned it has to be a G fast router, is that correct?
So i wasnt sure what routers on the market are compactable and if you think the improvement would be worth the cost of buying a new router to replace the standrard one. Just would I need to replace the modem is well?
So i was just looking for some help with these quries from someone with bit more knowledge in this area.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
17 REPLIES 17
on 11-02-2022 04:09 PM
Message 1 of 18
Will do thanks
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 11-02-2022 04:07 PM
Message 2 of 18
That's fine, if it doesn't fix it, then just let me know & I will PM some stuff to you.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 11-02-2022 04:05 PM
Message 3 of 18
Thank you keith, Yeah thats fine Im aware that there is no guarantee that this is will fix the issue and might just be the start of the process but either way I appreciate the help.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 11-02-2022 04:02 PM
Message 4 of 18
Our posts are obviously crossing the ether...of course, I will help you.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 11-02-2022 04:01 PM
Message 5 of 18
There is every chance @Sean97 that just disabling WiFi Optimisation will not fix the problem on its own, it is just the first stage of this. In that case please refer to the latter part of my reply in post #8.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 11-02-2022 03:59 PM
Message 6 of 18
Hi Keith sorry ive been inactive the past few days, I have just requested for the wifi optimisation to be disabled, once that has been disabled would you be able to help me with the next step as previously discussed. Thanks Sean
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 11-02-2022 03:57 PM
Message 7 of 18
Hi Chris sorry for the delayed reply yes can you please diabled that for me but i may need to to turn it back on in the future if that makes no improvement. Thanks
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 07-02-2022 08:25 AM
Message 8 of 18
Hi Sean97,
Just to confirm, would you like us to disable wi-fi optimisation on your line?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 06-02-2022 06:01 PM
Message 9 of 18
As I said, once WiFi optimisation is disabled, i'll send you some stuff and will do it all for you, free of charge as well.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 06-02-2022 04:22 PM
Message 10 of 18
Thank you keith far as I believe it is stil achiviated just I havent had talktalk disable it yet, Ill ask them to disable it if you think it will help resolve my problem. How would I go about getting someone to carry out a diagnostic?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 06-02-2022 04:12 PM
Message 11 of 18
Hi @Sean97
Have you had TalkTalk’s Wi-Fi optimisation disabled on your Sagemcom FAST5364 router? When this is enabled, as it is by default, it has the power to override any Wi-Fi configuration changes that I might suggest that you need to make. This will not help rectify this type of problem if Wi-Fi Optimisation is allowed to change my suggested settings. Only TalkTalk can do this for you, you cannot do it yourself. If not, just request they disable this for you in your reply.
The next stage involves sending out a guide to you to help you get me some important diagnostic results, so as I can analyse them for you and recommend changes to your router configuration to solve them.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 06-02-2022 04:04 PM
Message 12 of 18
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 06-02-2022 03:44 PM
Message 13 of 18
Thank you for your reply keith at this moment I am up for trying anything to improve signal strength
My current wifi stregnth using speedcheck is
Ping 24ms Download 19mbps Upload 21mbps
Device Verison
FAST 5364-3.T8
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 06-02-2022 03:22 PM
Message 14 of 18
Thats been added now thanks
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 06-02-2022 03:08 PM
Message 15 of 18
Ive currently got Fibre 150 installed in my two bed flat but the range is terrible and doesnt even reach the second between, plus the strength isnt good enough to play online gaming stable without lag.
Has anyone got this issue or is it possible to buy a third party router to place the factory box that was installed, i also heard it must be G fast compatible?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 04-02-2022 11:56 AM
Message 16 of 18
Hi Sean97
Please can you add your TalkTalk landline number to your Community Profile, we can then look into this further.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 04-02-2022 11:40 AM
Message 17 of 18
Whilst you can, this could be down to WiFi interference, which I might be able to help you sort this for free.
If you would like me to help you, please can you specify the make/model of TalkTalk router that you are using?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
