HUB
joesef
Message 6 of 6
Broadband has stopped working.
Raised a automatic line test which highlighted an issue and a fault has been raised. I have since noted there is no indicator showing on the HUB unit or a LAN indicator on the Openreach unit. All cabling is correctly connected. Is this  power issue with the HUB.
5 REPLIES 5
Message 1 of 6
I'm glad to hear this and thanks for letting us know 🙂
Message 2 of 6
Replacement Router has arrived and installed.  No issues.
Old unit will be posted back.  It seems to have an intermittent fault connected to the power supply.
Message 3 of 6
HI @joesef
Happy New Year 🙂
I've ordered the replacement router, please allow 24-48hrs for this to arrive.
joesef
Message 4 of 6
Hi and thank you for your prompt response.
If the line is OK and there appears to be no indication there is power to the HUB could please send a replacement unit.
Regards and Happy  New  Year.
Message 5 of 6
I'm sorry to hear this. I've run a test on the line now which is clear. Would you like us to send a replacement router for testing purposes to rule this out?
