on 30-09-2022 12:32 PM
Like others I have this fault.
See post of 31 Jan 2022 with same title.
It is most frustrating that TALKTALK technical support, contacted on the phone, won't look at this history and insist on speculating on other reasons.
My first call concluded with the I will get back to you in one hour.
After two hours with no ring back
I rang again and was cut off.
Is this the usual level of service??
on 06-10-2022 01:48 PM
Hi DonnyLad
If all other devices are connecting ok then this sounds like an issue with the Hive device, we don't block this.
Have you had a look at the Hive Community/help pages, I can see that they have some advice and checks to complete.
on 06-10-2022 01:42 PM
Just Green - Flashing = Installation and start up
on 06-10-2022 01:39 PM
Printers(3), Laptops(2), Desktop(2),Amazon Firesticks(2), mobile telephone(1) checked out ok.
They are a mixture of ethernet and wireless.
Hi DonnyLad
Also I'm just looking at Hive. Which lights are on the Hive hub at the moment?
06-10-2022 01:24 PM - edited 06-10-2022 01:33 PM
Hi DonnyLad
Are all other devices connecting ok? Is this only affecting the Hive?
Was the Hive hub working ok previously on your connection?
on 06-10-2022 01:22 PM
Both powered off for 40 mins.
The hive hub has not linked after 15 mins
on 06-10-2022 01:02 PM
Hi DonnyLad
How are you getting on?
on 06-10-2022 12:10 PM
Will Do
on 06-10-2022 12:09 PM
Hi DonnyLad
Have you rebooted both the Hive hub and router? It may be worth powering down both devices for 30 minutes.
on 06-10-2022 11:54 AM
The Hive Hub is connected to the router with a short ethernet cable.
10 mins ago I swapped the cable with another, known to be OK, with no effect.
06-10-2022 10:41 AM - edited 06-10-2022 10:48 AM
Hi DonnyLad
Ok, is your Hive hub connected wired or wireless?
on 06-10-2022 10:38 AM
Hi Debbie
Sorry to report no improvement.
on 06-10-2022 08:38 AM
Hi DonnyLad
Thank you. I've made a change to the firmware, please can you retest?
on 06-10-2022 07:51 AM
Hi Debbie
Go ahead with FW changes.
I won't touch any switches etc
on 06-10-2022 07:09 AM
Hi DonnyLad
Thank you. Will it be ok if I make a change to your router firmware?
We advise to leave the router switched on without being rebooted whilst we update the FW.
on 06-10-2022 06:43 AM
Good morning Debbie
Have now connected the the new router.
on 06-10-2022 05:53 AM
Hi DonnyLad
We no longer send out the Huawei WIFI hub. The Sagemcom hub should work ok with Hive.
Is the new router connected at the moment so I can check the firmware?
on 05-10-2022 08:19 PM
I am pleased to report a router/hub was delivered this afternoon (Wednesday). Great delivery service.
Having opened the package and removed the Network/Password Tab I found that the
Device Version was FAST 5364-3. T8 and it was badged "Sagem"
Regretfully my current router is also a Sagem FAST 5364-3. T8.
My understanding from other posts is that Hive successfully works with the Huawei DG8041W.
Would it be possible to have one to try?
on 05-10-2022 06:28 AM
Hi DonnyLad
Thank you 🙂
on 04-10-2022 06:41 PM
Thanks for organizing the router.
Will let you know how I get on.
