Hive hub not connecting with FAST5364
DonnyLad
Message 28 of 28
Like others I have this fault.
See post of 31 Jan 2022 with same title.
It is most frustrating that TALKTALK technical support, contacted on the phone, won't look at this history and insist on speculating on other reasons.
My first call concluded with the  I will get back  to you in one hour.
After two hours with no ring back
I rang again and was cut off.
Is this the usual level of service??
27 REPLIES 27
Message 21 of 28
I've another router on the way to see if this is hardware related.
DonnyLad
Message 22 of 28
Hi Karl
Thanks for speedy response.
Sorry to report no luck after sticking paper clip in the reset hole for 20 seconds
Message 23 of 28
the factory reset will not restore the original firmware but keep the current firmware.  Give the pin reset a try and lets see if this helps.
DonnyLad
Message 24 of 28
Hi Debbie
Thanks for getting back to me and updating the firmware.
I have
1.   Simply connected the Hive Hub to the router - no luck.
2.  Turned the router power off, waited, then turned power back on - no luck.
I have not tried resetting the router as I believe this restores the original firmware  that you have changed.
Am I right?
Be grateful for further advice.
Message 25 of 28
Hi DonnyLad
I've made a change to your router firmware, please can you retest and let us know how the connection compares.
DonnyLad
Message 26 of 28
Hi Michelle
Thanks for your advice.
Profile updated.
Sorry I am newbie and somewhat mature.
Message 27 of 28
  • Name
  • Telephone number
  • Alternative contact number
