Intermittent WiFi to all devices
AlexC2
Message 7 of 7
Hi, The WiFi from my talktalk router keeps intermittently (many times a day, usually after about 30 mins usage) dropping out when we’re close to it. It’s been happening a long time (months), but now I’ve had enough of switching WiFi off and back on..
Experienced on all device (3 different iPhones and Fire tablet), but iPhones more prone to issue ..
I read somewhere in the community there was some WiFi optimisation which might be causing.. Is that a possibility or has my router had it?
6 REPLIES 6
Message 1 of 7
How are you getting on?
Message 2 of 7
Thanks for that. First of all, you have mentioned that you have tried turning the WiFi off & on. That will cause you more problems as there is a bug with the current firmware versions, meaning the WiFi will not come back correctly. The only workaround to this at the moment is to perform a factory reset on the router. Log into the router & go to:-
Dashboard > See internet settings > Manage advanced settings > TalkTalk Wi-Fi Hub > Maintenance > Resets
Then click the Factory settings Reset button.
WiFi Optimisation cannot be disabled any more.
This is most likely a WiFi interference issue.
Message 3 of 7
Sagemcom, FAST 5364-4.T8
Message 4 of 7
Yes, FAST 5364-4.T8
Message 5 of 7
What make/model of router are you using?
Gliwmaeden2
Message 6 of 7
Wifi optimisation can't be switched off, @AlexC2.
Are you using the Sagemcom?
