Intermittent disconnection of broadband
Qwghlm
Super Duper Contributor
Message 14 of 14
Just started this morning, the internet connection repeatedly gets disconnected/connected
Tried turning the router off/on, still the same.
13 REPLIES 13
Message 1 of 14
Could you just see how it goes over the next couple of days. Hopefully your speed will improve.
Qwghlm
Message 2 of 14
Thanks for that.
Interesting that I've done absolutely nothing inside my home, but I did notice a Trooli guy fiddling in the terminal box at the end of my close on my out this morning...
Speed is down to 45mbps from 54mbps though.
Message 3 of 14
Hi Qwghlm,
I've just run a line test and it is now passing 🙂
Message 4 of 14
Thank you 🙂
Qwghlm
Message 5 of 14
Of course it's OK.
I did tell him the test detected an external fault, but he just said everything was OK externally.
Message 6 of 14
Thanks for the update. The line test did detect a potential external line fault. I'll re-run the line test again in a few hours (once the fault has been passed back) and will post the result back here if that's ok?
Qwghlm
Message 7 of 14
Openreach has just been and he says the fault is internal, which unfortunately I do not believe.
The connection hasn't dropped out at all last night or this morning so I will monitor it.
If it drops out again I will run a new temporary line to the router and go from there.
The reason I have my doubts is that over the past 15 years and it must be about 50 times Openreach have been out to sort the problem, it's always been external, never internal.
First time for everything I suppose, but we'll see.
Thank you for your help.
Message 8 of 14
We've received an update to advise that the fault has been assigned to a line engineer this morning so we should know more hopefully this afternoon.
Message 9 of 14
No problem 🙂 I should hopefully have an update for you in the morning, unless Openreach resolve the fault first.
Qwghlm
Message 10 of 14
Excellent, thank you very much.
I've received a confirmation message from Openreach as well.
Message 11 of 14
Ok thanks for confirming. As the line test is still detecting a potential external line fault, I've passed this over to Openreach now to complete an external line investigation. We'll check the fault first thing in the morning to see if we've received an update back and will post here.
Qwghlm
Message 12 of 14
No noise on the voice, and the router is not plugged into the test socket.
PC connected by cable to the router in a different room, the test socket is in the hallway near the front door.
Nothing has changes internally, (this normally happens when Openreach are sorting out another problem on another line somewhere).
Message 13 of 14
Good morning,
I'm sorry to hear this. I've run a test on your line now which has detected a potential fault. Can I just confirm, are you experiencing any noise on the voice service? Is your router also connected to the test socket?
